Dashboard not showing data consumption
- Als nieuw markeren
- Bladwijzer
- Abonneren
- Dempen
- Abonneren op RSS-feed
- Markeren
- Afdrukken
- Ongepaste inhoud melden
op 02-03-2025 14h58
For over a week now, the data consumption on my dashboard reads as 0 even though I have used data. I am concerned that I may be fast approaching my data limit. The correct consumption amount is displayed for telephone minutes and SMS. Any idea how this can be fixed?
- Bladwijzer
- Abonneren
- Dempen
- Markeren
- Afdrukken
op 05-03-2025 13h55
Hello Dotty, did you contact us already on our chatbot or our social media for this?
I would suggest you'd do that first, that you way you'll get in touch with our client services.
- Bladwijzer
- Abonneren
- Dempen
- Markeren
- Afdrukken
op 11-03-2025 18h11
hello, In my phone (it uses android) I can apparently monitor data usage in the phone itself. Your phone may have a similar tool built in? I never really looked into the workings of this because I set the phone to use wifi to run its software updates, and I do not use internet/games und so weiter on that phone so I have actually never used data on the provider carrier.. I would advise to use WIFI at home and where it is free as much as you can, rather than connect through the carrier phoneline.
